Re: The year this SC was made
Posted by farmallhal on June 12, 2012 at 11:03:57 from (76.4.180.11):
In Reply to: Re: The year this SC was made posted by Boonville Kid on June 11, 2012 at 21:30:42:
I looked at my 1953 Super C this morning and the engine s/n is exactly 8300 higher then the chassis s/n 1803XX - the engine s/n being 1886XX. Above the engine s/n the letters FCM and the engine s/n was stamped below the FCM on the same flat. The numbers were stamped much deeped and easier to read then the letters were which were really quite faint through the paint. The numbers were hidden right behind the governor control rod running along side the engine block above the distributor. Just push the rod down with your finger and hopefully your engine s/n will be visible. Hope all this helps so you can locate your engine s/n, Hal.
