Posted by Farmall450lpg on June 12, 2012 at 11:14:00 from (174.56.5.42):
In Reply to: Farmall 450 lpg clutch posted by Farmall450lpg on June 07, 2012 at 12:07:09:
Well i finally found time to split the tractor and i found out i did a very dumb thing. I put the pressure plate in backwards and that sure explains why it wouldn't disengage. This morning i drove it for the first time and it shifted great! I just wish i had done it right the first time so i didn't have to do it all over again. Finally i got to drive it!!!!! Thanks for the help, much appreciated.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
