Re: farmall h disillate manifold
Posted by Hendrik on June 12, 2012 at 11:18:34 from (77.171.150.157):
In Reply to: farmall h disillate manifold posted by jim warehime on June 12, 2012 at 10:28:40:
Do you mean the heat valve (flapper) inside the manifold is frozen? I had given up on my distillate manifold (Super A) because it looked like a solid piece of RUST. However, using heat, lots of penetrating oil, a hammer, an air impact wrench and a good helping of patience, it is functional again and the heat valve can be moved through nearly its entire range.
So do not give up too soon. I concur that finding a good one is difficult; so spend your time and effort on what you have got :-)
HTH, Hendrik
