Re: H squirting gas
Posted by old on June 12, 2012 at 12:44:50 from (209.86.226.34):
In Reply to: H squirting gas posted by fordhead1983 on June 12, 2012 at 12:26:32:
Float maybe sticking or you may have some dirt/rust in the needle seat causing the same problem. Try removing the drain plug from the bottom of the carb and let flue flow for a few minutes. Catch it so as to look for dirt/rust/water and also so you can reuse that liquid gold
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
