Re: H squirting gas
Posted by JRSutton on June 12, 2012 at 12:47:51 from (75.130.109.233):
In Reply to: H squirting gas posted by fordhead1983 on June 12, 2012 at 12:26:32:
Just flooding.
Probably due to floats not set exactly right - floats have a leak - or the little needle valve is clogged/defective.
if everything else is fine except for the occasional dripping - I'd personally leave it alone until winter comes around - then fix it.
not that it's particulaly hard to work on - just seems that bigger problems tend to happen once you start mucking around with them, or you loose a part - or whatever.
