Re: H squirting gas
Posted by Bob M on June 12, 2012 at 12:51:08 from (69.207.87.163):
In Reply to: H squirting gas posted by fordhead1983 on June 12, 2012 at 12:26:32:
Most likely you are using too much choke! What you see "leaking" from the carb is excess gas from overchoking draining from the drain port in the carb air inlet.
Suggested cold start procedure: Begin with the throttle at about 1/4 and the choke open. Now during cranking quickly "flip" the choke closed and back full open again. If the tractor is in good tune it should start right up.
