Re: H squirting gas
Posted by Zachary Hoyt on June 12, 2012 at 14:26:07 from (173.84.185.1):
In Reply to: H squirting gas posted by fordhead1983 on June 12, 2012 at 12:26:32:
I choke my H partially when air temps are below 50 or so and the
engine is cold. The rest of the time I push the throttle ahead all the
way and hold the starter button for 1 or 2 seconds while
simultaneously pulling the throttle about 1/3 open. It will usually
fire immediately and I push the throttle ahead again to a low idle
for a few seconds while it builds oil pressure. I used to have to use
the choke more when I was hand cranking the engine, but then it
was easy to flood. If you get too much gas in the carb just shut off
the gas at the tank till the engine starts.
Zach
