Re: Super A after 1 year of Restoration - Picture thread
Posted by CNKS on June 12, 2012 at 17:48:29 from (216.144.104.128):
In Reply to: Re: Super A after 1 year of Restoration - Picture thread posted by GRAPE-DRANK on June 12, 2012 at 16:35:28:
The sandblaster is a generic model made in China, etc and has several different names depending on who sells it. I have a identical one under a different name. It is slow, but works ok. It can be had with different size nozzles to match your compressor. The valve on the bottom must be adjusted to keep it from surging. Also best to screen the sand or it will plug the nozzles unless you have a compressor that puts out more than 24 CFM at 100 psi as mine does. Takes more time to screen the sand than it does to use it. It is faster and probably cheaper to have it "professionally" done. The commercial sand blasters actually use less sand. I can go thru a $100 worth of sand in a couple of hours and still not be done.
