Re: 454 and 350 Utility
Posted by charlie M on June 12, 2012 at 18:47:37 from (74.34.216.81):
In Reply to: 454 and 350 Utility posted by WI-Ed on June 12, 2012 at 18:33:11:
I can speak some about the 350u - without power steering they always steer hard.If the tractor has had a loader in its life time there could be damage to the gear box. I don't think parts are available if the gears are damaged. My 300U had a loader and even the pivot pin in the front end had to be drilled and replaced. If a beam fell on it there would have to be damage to the steering column if there was damage at all and that would be noticeable. You may be OK with just the new steering wheel.
