Re: 53 Super H
Posted by BUCK CLAYTON on June 12, 2012 at 20:31:27 from (70.189.103.148):
In Reply to: 53 Super H posted by Al Moyer on June 12, 2012 at 06:03:12:
Rusty; I know you have probably seen in past about oil filter canister sizes. We had a new 1942 H made in about april . 1942. It had the long filter on it. Some where around that time IH put a short filter on and then went back to long one for a while, mayby a mo. Then went back to the short filter some time after May or so in 1942. I think this is right. Been a long time ago. Buck
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
