Re: IH 340 Utility Carburetor
Posted by buzzinduzzin on June 13, 2012 at 03:01:19 from (66.220.92.37):
In Reply to: IH 340 Utility Carburetor posted by R A on June 13, 2012 at 02:26:58:
does the heat riser valve work, does it run smooth when you first start it & then start running rough after a while? I suspect carburetor ice build up
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
