Re: IH 340 Utility Carburetor
Posted by JRSutton on June 13, 2012 at 03:36:12 from (75.130.109.233):
In Reply to: IH 340 Utility Carburetor posted by R A on June 13, 2012 at 02:26:58:
The manifold gets cold right there from the expanding air/gas out of the carb - and so condensation forms on the manifold.
So that's not to say you don't have a leak - just that the moisture is normal.
Unless the engine smooths out from choking it a little - or you see black smoke coming out - I'd focus more on the ignition side of things.
Easiest thing to do first would be adjust and clean the points. And make sure your plug wires are in good condition - and inside of cap is clean and dry.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
