Posted by Dean Olson on June 13, 2012 at 05:35:23 from (98.196.66.64):
In Reply to: Super H Oil Pressure posted by Global Warmer on June 12, 2012 at 18:40:42:
I have a 53 SH that I rebuilt the engine and a 54 SH that PO rebuilt the engine. 53 SH will hold about 65 at idle and 75psi at WOT. The 54SH holds 55psi at idle and 70 at WOT.
My Farmall 200 had 20psi at idle and would not come up much at WOT. I pulled the pan and removed about 2" of sludge. Pump gasket had blown out the side. Cleaned it all up and repaired pump and still didn't have good pressure. Upon further investigation I found that the hole in the side of the oil filter housing bolt was plugged. That fixed the problem and I now have good pressure.
Grandfather taught me to run heavier oils in worn engines. Try some 20w-50 and see what that does for you.
That's the easy stuff. If none of that helps it's time to rebuild the engine.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
