Well first off the manifold getting cold or even having frost is normal and if it does not happen then you have a problem. As for your real problem many things can cause that. Poor fuel flow, or weak spark or a clogged air cleaner. You need to do your trouble shooting first then parts. Check your spark it needs to be a blue white and jump a 1/4 inch gap or more. Next if you have that pull the drain plug form the bottom of the carb and let the fuel flow for a few minutes. Catch it so as to look at it for water/dirt/rust. Also check your air cleaner and make sure it is not full of dirt and or water.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
