Re: Super H Oil Pressure
Posted by rustyfarmall on June 13, 2012 at 13:54:43 from (67.55.162.174):
In Reply to: Super H Oil Pressure posted by Global Warmer on June 13, 2012 at 13:26:24:
First, make absolutely certain that ALL the bolts are out, including those that kind of like to hide in the crud at the rear. If indeed all of the bolts are out, then the only thing holding it on is the glue on the gasket. Give it a good thumping with your hand, or insert a thin bladed putty knife in between the pan and engine block.
