Re: Super MTA T/A check and operation
Posted by Janicholson on June 13, 2012 at 14:24:55 from (199.17.6.27):
In Reply to: Re: Super MTA T/A check and operation posted by bvaughn85 on June 12, 2012 at 19:24:31:
The TA friction clutch is a 2/3 sized regular disk clutch with throwout bearing. When going from TA reduction to direct, it takes up the speed difference as it engages. If the lever is moved slowly, it is slipping as it makes the transition. Like someone does not know how to use a manual trans clutch. It is driving in TA reduction, and slipping in direct. When moved rapidly, the disk wear is minimal, and the transition is just like an automatic trans shift.
When pulling it into TA, (again) rapidly reduces slippage time as the friction material allows the TA reduction to take over. Fast motion is the answer, along with using it often. Jim
