Re: should i re sleeve my farmall M?
Posted by Janicholson on June 13, 2012 at 15:38:05 from (199.17.6.27):
In Reply to: Re: should i re sleeve my farmall M? posted by rbooe05 on June 13, 2012 at 12:40:51:
Giudes are not hardened, seats are, or can be) hardened. Seat inserts or ceramic, or stellite (an Iron Nickel Cobalt alloy + other things) to make the seat hard and heat resistant.
The sleeve taper from most worn (at top ring stopping point) to least worn (Bottom of sleeve)can be accepted if less than .004". Ridge ream the top, and hone to allow the rings to seat. If more than that, new sleeves/pistons are a best practices tactic. Jim
