Re: international 574 diesel radiator fill level ?????
Posted by jimb2 on June 13, 2012 at 18:26:06 from (99.241.38.122):
In Reply to: international 574 diesel radiator fill level ????? posted by kevin oh on June 13, 2012 at 17:55:28:
Hi Kevin, a few dependencies:
1)Is it water only?
2)Is it 50/50 antifreeze/water mix?
3) Temperature of coolant? Never open Rad cap when HOT.
Here in Canada we use 50/50 mix and in warm summer day before engine has been started, coolant level of 1 inch below top of Rad tank is good. If it is to full it will discharge out overflow when engine gets hot. In winter if coolant is visible above core is usually good.
JimB
