Re: Farmall A - PTO pops out
Posted by gene bender on June 14, 2012 at 05:13:21 from (67.55.226.59):
In Reply to: Farmall A - PTO pops out posted by rpirkle1 on June 13, 2012 at 08:19:09:
Your coupler shaft is worn and worst would be the main shaft in the tranny is rounded off. I have some good coupler shafts is you need one. Now you can remove yours and file it giving it some "new" edges to help hold it in gear. Never hold the lever to keep it enguaged or you will burn off the "button" on the shift lever. If you would like you can call me as ive helped some others with the same problem. 319-430-3907
