Re: voltage regulator question
Posted by rustyfarmall on June 14, 2012 at 05:33:15 from (67.55.162.174):
In Reply to: voltage regulator question posted by Pat Connors on June 14, 2012 at 05:23:26:
A fully charged 6 volt battery SHOULD read right at 7 volts. Anything less might indicate a problem with either the generator OR the voltage regulator.
The headlights not working is un-related. Either they are wired incorrectly, the switch is bad, the bulbs are bad, or most likely, you still do not have a good ground.
