Posted by rustyfarmall on June 14, 2012 at 05:45:40 from (67.55.162.174):
In Reply to: Super H Oil Pressure posted by Global Warmer on June 13, 2012 at 17:29:27:
Yes, remove the entire oil pump assembly. There is only one bolt holding it in, but after removing that bolt you will need to rotate the assy back and forth while pulling down. Usually they come out fairly easy, so be careful to not drop it. Once you have it out, take it to your work bench and then remove those 4 bolts that hold that bottom cover on. There is a heavy spring under the cover that will push up against the cover as you remove the bolts, so you will need to loosen the bolts evenly as you go. By the time the 4 bolts are loose, the pressure will be off the spring, so no, it will not fly off. Once the cover is off, you will see what needs to be done.
I like to hold the oil pump assembly upside down in the bench vise. that way those two gears inside will stay put and not fall out.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
