As wired from the factory the light switch gets its power from the regulator "L" terminal. If the VR is missing and the light switch hot wire was not relonnected to another source of 6 volts, the lights will indeed not work.
Also, from the factory the lights should have dedicated ground wires. (The steering post is notorious for grounding poorly or not at all). Suggest running a ground wire from each light and attaching it to the BASE of the VR.
A fully charged 6 volt battery should read about 6.6 volts at rest. Your voltage readings suggest the battery is somewhat discharged. Also that is not being charged when the engine is running - exactly what you'd expect when the VR is missing(!)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
