Re: should i re sleeve my farmall M?
Posted by El Toro on June 14, 2012 at 08:59:24 from (108.3.225.57):
In Reply to: Re: should i re sleeve my farmall M? posted by rbooe05 on June 13, 2012 at 16:02:16:
Use your fingernails on top of the sleeves and see how much ridge you have. You probably need to use a ridge reamer if you're planning on using the pistons. You may be able to use a glaze breaker on the sleeves and install a new set of rings. You need to check your bearings for wear. Hal
