Re: Clutch/pressure plate removal
Posted by Jim Becker on June 14, 2012 at 14:47:56 from (173.74.120.222):
In Reply to: Clutch/pressure plate removal posted by old on June 10, 2012 at 12:24:18:
Since you are sure the lining isn't stuck (as clutch functioned coming into the shop), the pressure plate must be stuck at the edge. I think the very edge is the only hard contact between the pressure plate and flywheel (may be remembering that wrong).
Loosen the 3 bolts you moved in to the inner holes. Leave them with a couple turns worth of slack between the heads and the face of the pressure plate. this will leave the pressure plate springs all pushing out on the pressure plate but keep things under control when it breaks loose. Then rap the edge of the pressure plate with a hammer. Don't go crazy with the hammer. If that doesn't free it, apply some heat along the edge of the plate and let it cool. try the hammer again. Prying on it while hammering can't hurt anything either.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
