Re: Distillate A
Posted by athol carr on June 14, 2012 at 21:02:10 from (115.188.3.223):
In Reply to: Re: Distillate A posted by Greg Farmall A on June 14, 2012 at 14:05:58:
I would run on gasoline. If you read the manuals, it states that it may just use gasoline, but take the manifold shield off. With the current price of kerosene it is a no brainer choice. The use of kerosene implies greater oil use (you drain a pint off every morning caused by dilution of the oil with kerosene going past the piston rings) greater engine wear (the condensing kerosene washes the oil off the cylinder walls if the engine is not kept HOT) and more frequent oil changes.
