Re: starting a previously stuck engine: precautions?
Posted by Duner Wi on June 15, 2012 at 05:52:01 from (216.226.80.242):
In Reply to: starting a previously stuck engine: precautions? posted by mike_sdak on June 15, 2012 at 04:27:32:
I would back odd the valve adjusters so all valves are closes.
With piston at bottom of stoke I would fill cylinder with oil and use compressed air hooked to spark plug adapter to force oil down past the cylinder to wash away possible debris. Do this on all cylinders one at a time. Drain oil and fill with new oil. Check for stuck/sticking valves. Adjust valves lash and start it up.
Might be overkill but you seem to have pretty good patience. Good luck!
