Before you start doing anything serious to the motor you need to get those fuel filter set up correctly. The manufacturer put a double filter there for a reason. Same goes for the fuel return line. Set it up as it should be. Running the pump leaner is unlikely to help you. If you want the pump reset, get someone with the right equipment to do it. Same for the injectors. Take them to a diesel place and get them overhauled. It isn't a cheap way to go, but far less costly than destroying a piston due to a dud injector. I work with Scania and Mercedes diesels. Bosch pumps are practically indestructible unless you do something really bad to them.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
