Re: Runaway engine speed Farmall C
Posted by d beatty on June 15, 2012 at 09:06:48 from (24.12.128.253):
In Reply to: Runaway engine speed Farmall C posted by LarryD(VA) on June 15, 2012 at 08:56:39:
I take it this was your first start up of tractor. Did you check the linkage from govenor to carb.to see if its stuck? Also check the carb to see if throttle plate may be stuck. If this is all free than its a problem in the govenor.
