Re: Runaway engine speed Farmall C
Posted by Bob M on June 15, 2012 at 09:21:48 from (69.207.87.163):
In Reply to: Runaway engine speed Farmall C posted by LarryD(VA) on June 15, 2012 at 08:56:39:
For whatever reason the governor is not closing the carb throttle on RPM increase.
Test by setting the governor handle to idle. Then grab the governor to carb link - it should move freely by hand. If it does not, disconnect link at the carburetor end and determine where it's stuck (carb or governor).
If it's stuck at the carb end you'll need to remove the carb and free up the throttle shaft.
Otherwise you'll need to go inside the governor and determine the problem.
