Re: IH 484 burns my eyes-strong fuel smelling exhaust
Posted by pete 23 on June 15, 2012 at 09:45:06 from (74.32.229.231):
In Reply to: IH 484 burns my eyes-strong fuel smelling exhaust posted by south_ms on June 14, 2012 at 20:34:52:
Your pictures show a Neuss built engine, D-179
which is referred to as the German diesel. IH had
many, many service bulletins out about that eye
burning stinking engine. One guy even claimed his
cows got sick when he used that style engine in
the barn and was taking IH to task over it. So,
what they did was made a higher compression piston
and changed the injection nozzles to low sac
nozzle tip. The nozzle made for less dribble after
injection and the compression ratio raised the cyl
temp for more complete combustion under light or
no load conditions. You cannot lean out a diesel
as you do a gasoline engine BECAUSE the amount of
fuel you inject is what controls the speed of the
engine. When you make adjustments to the pump like
giving it more or less fuel you are adjusting the
limits of how much fuel it can deliver. In other
words, adjusting a stop for maximum movement.
Timing of injection effects smoke and running but
more than likely your problem is lack of heat, and
I don't mean coolant temp, I mean combustion
temperatures. Put it to work, and then see what
you have.
