Posted by AG in IN on June 15, 2012 at 13:49:45 from (67.236.106.64):
In Reply to: 1939 F-20 worth posted by mkirsch on June 14, 2012 at 05:35:48:
sdmike said: (quoted from post at 21:09:06 06/15/12) It is not a "farmer engineered" post hole digger.:-) I was told by my FIL many years ago it came with the tractor when his dad bought it. I have never seen another post hole digger like it. Mike
It's definately not farmerized. I have a similarly constructed post hole digger on a Farmall H. Mine says "ATOM MFG. CO. MOLINE, ILL" on the top of the gearbox. Mine doesn't have the handwheel, it has a really long hydraulic cylinder to raise and lower the auger. It has a 2-way hyd. valve that the control rod goes to a shorter bracket where your handwheel is. The way it pivots on the front and the upright supports are the same. Looks like the same angle iron and the same adjustment lever along the side of the tractor. Is the shaft that goes through the gearbox hex-shaped and is there a thrust bearing at the top?
I always wondered if the operator could drill out a tunnel with it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
