Hi South_MS, I reviewed your photos again looking at the injection pump and I think someone has backed out the power screw on your injection pump to the max so engine is probably being over fueled. The power screw is the front screw that the STOP/START/RUN lever limits against. If your STOP/START/RUN lever is working properly, don't pull the lever all the way to the top of the slot and the lever on the side of the pump will no longer be limiting on the bottom front power screw. That should make the D-179 run a little leaner and clean up some smoke but you need to give it a good hard workout.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
