Re: Opened thermostat housing and no thermostat !!!!
Posted by Dean Olson on June 16, 2012 at 06:09:40 from (98.196.66.64):
In Reply to: Opened thermostat housing and no thermostat !!!! posted by BigTone on June 15, 2012 at 16:58:00:
It's overheating due to a problem with the radiator being plugged,or, water pump not working,or, thermostat sticking closed,or, cooling jacket in motor being full of sludge.
It seems to be really common for the thermostats to be gone on Farmalls.
I've heard of the "overheats because of no thermostat" but have never had it happen on any vehicle I've ever owned. I can't quit wrap my mind around the concept that "moving the coolant through the radiator faster" can make it accumulate more heat. The radiator removes heat!
I did remove several thermostats on junk cars back in the day in an attempt to get them to run cooler. At the time I was too broke to afford proper repairs. It's definitely a band aid fix that didn't always work. It was sure miserable in the winter time when the coolant didn't get hot enough to provide heat.
