Re: Runaway engine speed Farmall C
Posted by rhtx55 on June 16, 2012 at 07:57:47 from (207.119.48.22):
In Reply to: Runaway engine speed Farmall C posted by LarryD(VA) on June 15, 2012 at 08:56:39:
Ther is a thru shaft that runs across the front of the engine from the governor to the carb. Remove the governor housing and replace the shaft seals & bushings. Adjust the carb to shaft linkage per the manual. This is quite common on the C's & Super C's.
