Re: IH 300U Clutch Adjustment
Posted by CNKS on June 16, 2012 at 08:59:08 from (216.144.104.128):
In Reply to: IH 300U Clutch Adjustment posted by Ben Pung on June 16, 2012 at 05:09:12:
Hytran is equivalent to 10 weight, you can get compatible hyd oils that are 20 weight, I believe one is 303 bought at Orscheln, etc, Tractor Supply also has one. I posted a similar question a year or so ago, most people said it wouldn't work, but it helped my 460U, not as much as I would like, but better. The gear clash is why there are transmission brakes on later models. Mine usually shifts ok if I don't let the clutch out between shifts. If I do, I idle the engine and wait 10-15 seconds with the clutch in.
