Re: 656 hydo hydraulic issues
Posted by pete 23 on June 16, 2012 at 13:21:23 from (74.32.229.231):
In Reply to: 656 hydo hydraulic issues posted by ChShaffer on June 16, 2012 at 12:52:23:
First off, are you checking the fluid level with engine that is running and has run for a few minutes to fill the hydrostatic drive housing. Second, you could look into the rear through third arm mounting hole and check for loose or broken hose or pipe on suction tube.
