You could, but it would be far easier to fit a shim. You need a shim which is flat washer shaped. I.D. just large enough to fit over the castellated nut and O.D. just small enough to fit inside the threaded section of the sector wheel housing. If the castellated nut is fouling the retaining cap, you should see marks inside the cap where the nut, or possibly just the split pin (I think usually called a cotter pin in the U.S.?) have been contacting the cap. If it is just the split pin the problem is easily fixed by bending it or replacing with a different pin.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
