Getting the arm off can be tough but it does need to be removed so the two halves can then be seperated. There are two seals one on the steering shaft and the other on the output shaft. There is also two bushings and a bearing. During the process make sure the grease in the spindles gets to the bottom where the flange rides. I would also replace the bolt holding the steering arm so you have a good surface for your wrench to fit as over the yrs some poor work was done and the head and nut are rounded. I fill with 90wt so the worm and gear get the lube they need. I have done several its quite a job but good steering when done.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
