Re: IH 300U Clutch Adjustment
Posted by Ben Pung on June 17, 2012 at 04:05:40 from (166.249.133.227):
In Reply to: IH 300U Clutch Adjustment posted by Ben Pung on June 16, 2012 at 05:09:12:
Sorry, I should have mentioned that I do not have a T/A. I will try the test the Jim mentions and post back. Thanks for the help...
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
