Posted by Janicholson on June 17, 2012 at 06:14:35 from (67.72.98.45):
In Reply to: H Steering Worm Gear posted by George Rausch on June 17, 2012 at 04:05:09:
As Zach points out, it could be a loose bearing in the housing. The ball bearing under the cap is critical to tightness. If the shaft can move in or out at all when turning the wheel through its freeplay that bearing is the issue. Clean well around the hole where the shaft comes out of the housing toward the driver. Mark it all around with a sharpie while it is being held at one end of the freeplay (bungie). Then turn it the other way and see what happens to the mark. Another test is to feel the bolster shaft where it passes through open space just below the steering box while someone steers through the freeplay. Forward and back mocement there (not around and around) is a worn upper shaft bushing. Quite common. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
