Re: Super M Hydraulic Pump Removal
Posted by sflem849 on June 17, 2012 at 14:39:34 from (69.197.84.39):
In Reply to: Super M Hydraulic Pump Removal posted by The Red on June 17, 2012 at 14:29:14:
I have done a modified method of that with a floor jack and two bolts with the heads cut off. I just put them on opposite corners. It actually helps line the drive coupler up when reinstalling since angle of the belly pump is so important on an M. On and H you just slap it in there when everything is in place so it is simple.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
