Re: Super C won't start
Posted by El Toro on June 17, 2012 at 16:31:52 from (108.3.225.57):
In Reply to: Super C won't start posted by Smith1000 on June 17, 2012 at 15:57:28:
I would pull the valve cover then crank over the engine and see if all the valves are opening and closing. If they're not moving you may have a broken camshaft or cam gear. Run a compression test on all the cylinders. If this checks out ok pull the distributor and see if the gear on the distributor has failed. Spin the engine over and see if you have oil pressure on your gauge. If there's oil pressure I don't think there would be any cam or camgear problem. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
