Posted by Jim Becker on June 17, 2012 at 17:22:22 from (173.74.120.222):
In Reply to: Super C won't start posted by Smith1000 on June 17, 2012 at 15:57:28:
First thing, make sure the rotor is completely in place so that it should be turning. Next step, I'd pull the distributor off (whole thing including the 2:1 drive adapter). You can then see if the distributor drive turns when you crank the engine and if the rotor turns when you turn the distributor input.
It is not unheard of for a gear in the timing gear train to loose some teeth.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
