Re: Need Governor For Super H What Else Fits It
Posted by D Slater on June 18, 2012 at 07:07:34 from (184.15.43.82):
In Reply to: Need Governor For Super H What Else Fits It posted by Benjaminmn on June 18, 2012 at 06:40:49:
SH is the only correct complete bolt on. Throttle tube to carburetor on a H is longer. You can change tubes. 300 and 350 has the wrong throttle lever. You can change that.Every thing else on the 300, 350 works. M to SMTA has the wrong top casting, linkage rod, tube and drive gear. All of that can be changed out to work. 400 and 450 has all the wrong parts a M to SMTA does and also the throttle lever. Depending whats wrong with yours other governor internals can go in to repair it if needed.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
