And while we're at it - if you DO decide to go with the kit (which can help clean up slop in the steering) Most of the stuff is pretty straight forward - really only one way it can come out and go in.
However, the old brass bushings can be REAL tough to remove. The best way I found to get them out was to take a hacksaw blade - insert it through the hole and cut the bushing lengthwise all the way through - you can nick the cast iron without causing a problem, but obviously keep it to a minimum.
It's best to make two opposing cuts - then the remaining bushing halves will knock right out with a chisel.
Your oil seal on the top of the steering box where the steering shaft goes through is probably a double thickness leather seal. The new one will be half the thickness, don't let it concern you - try to seat it flush with the top of the hole - you'll see what I mean when you get it.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
