Re: Removing RTV silicone from castings
Posted by pete 23 on June 18, 2012 at 10:48:19 from (74.32.238.2):
In Reply to: Removing RTV silicone from castings posted by keithg on June 18, 2012 at 09:19:00:
The RTV sealers are normally very easy to get off,
it is the anaerobic type sealers that are hard to
remove. They dry very tough in the absence of air
where as the Room Temp Sealer (RTV) cures when
exposed to the air but never gets really hard.
