Re: F-20 doesn't start
Posted by El Toro on June 18, 2012 at 14:15:35 from (108.3.225.57):
In Reply to: F-20 doesn't start posted by Bill Thompson on June 18, 2012 at 10:39:33:
Replace the condenser and remove one of the sparkplugs and reconnect the plug wire to the plug. Then press on the hex on the sparkplug against the engine block while a helper cranks over the engine. It won't shock you and see if there's fire to the plug. As mentioned listen for the impulse coupling snapping when cranking.
The spark should be hotter when it snaps. Hal
