Re: Removing RTV silicone from castings
Posted by Kevin Meier on June 18, 2012 at 14:23:56 from (174.253.142.102):
In Reply to: Removing RTV silicone from castings posted by keithg on June 18, 2012 at 09:19:00:
I rebuild water pumps and t/a"s for a living. Lots of rtv to
remove. I use a plastic brush type wheel on a drill made by
3m and follow up with a shot of brake kleen for residue. I like
the plastic because its not aggressive enough to remove the
metal and still does a fantastic job.
