Posted by Dennis K (WA) on June 18, 2012 at 14:44:39 from (24.21.78.195):
In Reply to: A front trans seal posted by blunted on June 18, 2012 at 07:55:43:
Blunted, I just did what you are wanting to do, to my 'C'. and it worked out ok. I have an overhead crane which supported the front half and I blocked the rear. Rolled the front away just far enough to separate the shaft from transmission and then move the front out of the way. Replace what you are going to replace and roll it back as close as you can, reassemble the joint and move it together. The sleeve/tube that supports the throwout bearing will support the front of the shaft and your clutch plate will already be inline. You could also file a slight chamfer on the shaft splines to help with engagement of the shaft. I used long line up bolts when I rolled it back together.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
