Re: A front trans seal
Posted by cheif on June 18, 2012 at 18:40:08 from (184.61.129.34):
In Reply to: A front trans seal posted by blunted on June 18, 2012 at 07:55:43:
I had good advice when I did mine. Split it the trans but only open it a couple inches while you decouple the joint you will see there. Just be careful you don't pull the drive shaft back too far then no trouble with the clutch connection.
